How can a user choose which caller ID is shown
Discussion in '3CX Phone System - General' started by Emily Frank, Oct 9, 2017.
Tags:
  1. Emily Frank
    Oct 4, 2017
    I have a user who has multiple DIDs that point to her extension. She would like to choose what caller ID appears when she makes a call (i.e. when she makes a sales call, the sales number shows up. a vendor call, the vendor number shows up, ect).
    Is there a way to set that up? a code to type in or a BLF to program?
    11,092
    326
    As I seem to recall seeing, an option to change CID , using a dial code, is being considered. I think your only option, at this point would be to assign multiple extensions to the line keys, and assign a different CID to be displayed on outside calls , to each.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Or to make multiple trunks, one per DID, instead of one trunk, if provider allows this.
    Then you can select which trunk to use with some prefix, like *70, *71, ..., *79 and caller-ID assigned to trunk will be used.
