- Joined
- Mar 25, 2014
- Messages
- 13
- Reaction score
- 0
Hello 3CX team,
if compiler errors occur, I would like to quickly see in which component the error is located.
How can you now find out where the error is. The specification of a line number in the * .flow file would be an advantage.
Example:
Error library code: (342,141): error CS1503: argument 1: can not convert from 'int' to 'System.Collections.Generic.List <object []>' "
The .NET error is clear so far, but this is the parenthesis value.
Thank you.
In this case I will get the customer number from a Query.
Example:
Thank you.
