how can I check a phone number?
Discussion in 'Call Flow Designer' started by luca pellegrini, Oct 2, 2017.
  1. luca pellegrini
    Sep 14, 2017
    11
    I should check the phone number to know if there are more than 9 digits or less
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,067
    75
    Hi @luca pellegrini,
    Do you mean the caller ID number? In that case, in order to check if the length is 9, you can use the following expression:
    EQUAL(LEN(session.ani),9)
    If you want to check if it has less than 9:
    LESS_THAN(LEN(session.ani),9)
    Kind regards.
  3. luca pellegrini
    Sep 14, 2017
    11
