How can i configure Dlink DGP-202SP phone with 3cx
Discussion in '3CX Phone System - General' started by vinodkrmishra, Feb 27, 2007.
  1. vinodkrmishra
    Feb 26, 2007
    I have installed 3cx phone system for windows. I have purchased some DLINK MAKE DGP-202SP phones. How can I configure ? Please reply.
    Thanks,
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    As you will find HERE the model you mentioned has not being tested with our system.
    That does not mean that it will not work, however that means that we don't have a configuration to give you for that model. Since we have tested with many different types of phones, and they are all very similar in configuring, you would benefit from reading the manual (the "configure a hardware based sip phone" section) and the configurations we have on the support/faq page on the website for other phones.
