How can I disable the STUN server?
Discussion in '3CX Phone System - General' started by softvision, May 13, 2008.
  1. softvision
    May 13, 2008
    how can I disable the STUN server? I don't need any STUN server, because I have a direct connection (via leased line) to my VoIP provider. I always use local IP addresses with my VoIP provider. I have removed all settings under "General Settings -> STUN server options", but I still receive the message
    [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    every 10 secons.
    Bernd
  2. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    take a look on http://www.3cx.com/support/sip-dns-configuration.html. maybe is this what do you are seeking. :lol:
  3. softvision
    May 13, 2008
    Hi, thanks for you post, but this isnt what I am looking for. I just want to remove the STUN server as described in the help message of "General Settings > STUN server options". I have deleted all the values but I still receive the warning message in the log file. Either the description is wrong or there is a bug. Maybe someone of the 3cx stuff reads this and can answer the question.
  4. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    take also a look on: http://www.3cx.com/forums/voip-provider-can-not-register-when-stun-is-removed-5325.html there in stay that in v5 "WIthout stun registering wont work at all. Thats to be expected " from NIck.
  5. otaku-oni
    Feb 7, 2007
    8
    If you can't beat them , join them.
    What is the harm if you make it work ? put a stun server there. The PBX will contact the STUN server and the STUN server will reply saying there is no IP/PORT translation.
    All SHOULD work from there on. I'ld give that a try.
    If it works still speak to support as you may have stumbled on a bug or so :)
  6. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    Hi OTAKU-ONI
    you are a wise man. sometimes we have to realise ourself that the technic is going on. but about stun server: you need them.
