How can I enable G711 for my extensions?
Discussion in '3CX Phone System - General' started by georgi0, Feb 6, 2018.
Tags:
  1. georgi0
    Feb 14, 2017
    32
    how can I enable G711 for my extensions?
    Currently, i only see these under provisioning:
    PCMU
    PCMA
    G722
    G729
    G
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,423
    187
    Hi georgi0,
    Where are you located ? You have PCMU and PCMA here which are G711u and G711a.
    Commonly A Law (a-law) is used mainly in European PCM systems , and the µ law (u-law) is used in the US.
    YiannisH_3CX likes this.
