How can i enable multi calls on one extension?
Discussion in '3CX Phone System - General' started by Ahmadi, Sep 20, 2009.
  1. Ahmadi
    Sep 17, 2009
    10
    I have a SIP Client that is connected to 3CX, it can answer multi concurrent calls but 3CX don't allow it:
    Here is my log
    Code:
    16:00:13.078  [CM503008]: Call(40): Call is terminated
    16:00:13.062  [CM503015]: Call(40): Attempt to reach <sip:100@169.254.82.175:5060> failed. Reason: Busy
    16:00:13.062  [CM503014]: Call(40): No known route to target: <sip:100@169.254.82.175:5060>
    16:00:13.062  [CM503010]: Making route(s) to <sip:100@169.254.82.175:5060>
    16:00:13.062  [CM505003]: Provider:[test001] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-SIPGateway/IOS-12.x] Transport: [sip:10.45.20.17:5060]
    16:00:13.062  [CM503001]: Call(40): Incoming call from 2243111@(Ln.20003@test001) to <sip:100@169.254.82.175:5060>
    16:00:13.047  [CM503012]: Inbound out-of-office hours rule (unnamed) for 20003 forwards to DN:100
    16:00:06.916  [CM503007]: Call(39): Device joined: sip:100@192.168.74.58:5060
    16:00:06.900  [CM503007]: Call(39): Device joined: sip:2212210@10.45.20.20:5060
    16:00:06.900  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VaxSIPUserAgent/3.0] Transport: [sip:10.45.20.17:5060]
    16:00:06.900  [CM503002]: Call(39): Alerting sip:100@192.168.74.58:5060
    16:00:06.604  [CM503024]: Call(39): Calling Ext:Ext.100@[Dev:sip:100@192.168.74.58:5060]
    16:00:06.604  [CM503004]: Call(39): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.74.58:5060]
    16:00:06.588  [CM503010]: Making route(s) to <sip:100@169.254.82.175:5060>
    16:00:06.588  [CM505003]: Provider:[test001] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-SIPGateway/IOS-12.x] Transport: [sip:10.45.20.17:5060]
    16:00:06.588  [CM503001]: Call(39): Incoming call from 2212210@(Ln.20003@test001) to <sip:100@169.254.82.175:5060>
    Thank you for your attention.
    H.Ahmadi
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi H.Ahmadi,
    We are providing two manuals for each version of our PBX - first for administrators and second for users of PBX.
    It contains description of configuration options as well as available features. All links to installation file, change log, and documentation are available in 3CX blog.
    P.S. I've forgot to specify that it is an extension setting. See description of "forwarding rules". By default it is set as "Use PBX status"
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Edit the extension, go to the Forwarding Rules tab, at the bottom change the busy detection mechanism from PBX Status to Phone Status.
