How can i export phonebook from Softphone ?
Discussion in 'Windows' started by cgs2008, Feb 11, 2010.
  1. cgs2008
    Sep 8, 2008
    I want to export Phonebook from my Softphone into another Softphone installed on another PC..
    how can i do this ?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    I suppose you are referring the 3CXPhone. In this case, there is not a "export phonebook" feature available yet.
    However, you may do this in an "unsupported way", by simply copying your phonebook folder, usually
    C:\Documents and Settings\cgs2008\Local Settings\Application Data\3CX VoIP Phone\Phonebook
    in the similar place on the target machine.
    Hope it helps
    vali
  3. cgs2008
    Sep 8, 2008
    Yes ! Ok !!!
    Thank you very much !
