How can I get phone IP by called extension in API?
Discussion in '3CX Phone System - General' started by oxy_naum, Nov 10, 2009.
  1. oxy_naum
    Oct 13, 2009
    8
    I see in ActiveConnection.DN/InternalParty property PhoneDevices, but it's not always actual :-(
