How can I get video?
Discussion in 'Windows' started by Zoom123, Jun 29, 2011.
  1. Zoom123
    Feb 2, 2011
    7
    I recently installed 3CX to try it out. I also installed the 3cx softphone, one on the same PC as the server, and another one on another PC on the same LAN. I can use the softphones to make calls and talk to each other.
    One of the computers has a webcam and in the preferences of the 3CX phone I enabled it, but I see no video. What should I do?
  2. Zoom123
    Feb 2, 2011
    7
    anybody?
  3. willow
    willow Member
    Mar 1, 2011
    471
    you may need to play with the preferences. there are options for starting video automatically and such.
  4. stillabdul
    Mar 13, 2009
    8
    Under preferences, have you also selected the video source? The other thing, is that on the phone (what version are you using?), there is a bar on the right that you would have to click to actually see the video. Thanks.
