How can I link PSNT and VOIP gateway??? Help please
Discussion in '3CX Phone System - General' started by Leonid Ruiz, Jan 10, 2008.
  1. Leonid Ruiz
    Jan 9, 2008
    Hello everyone.
    This is my fist time I install this system, also I'm using a SPA-3102, this is what i did.
    1- I created 1 extention.
    2- create the PSNT.
    3- configure de spa-3102 according the manual on 3cx.com
    4- check line status (bouth are green).
    5- add voip gateway
    6- configure the RD using any wav
    I made all this using the manual.
    Now, when I make the phone call from an analog line ring 2 times, I listen something, continue ringing and a local operatior answer.
    What seems to be the problem... why cannot link the psnt with the voip gateway.
    Thank you. :?
