How can I make 3CX Caller ID show names and numbers?
Discussion in '3CX Phone System - General' started by ingram, Dec 30, 2013.
  1. ingram
    Oct 24, 2013
    11
    Currently, our phones and softphones only show the number of the caller. Does anyone know how to make them show the name of the caller also? I have a SIP trunk from Intelepeer.
    10,835
    294
    That all depends....
    If the provider does not send a name, then all you can do is to enter the number and a name in the 3CX phone directory. That will display any name you wish if there is a number match. You can also change a name that is being sent to something more meaningful, such as "Mobile Caller", to a persons actual name. Of course this only works for frequent callers that you go to the trouble of putting in there.
    Some providers, depending on the country/policy, do offer a name display service, but charge extra, as a name lookup in a database generally has a fee.
    Check the 3CX logs for an incoming call, to be sure that a name is not being sent.
