How can I make call from public phone to 3CX and use ...
Discussion in '3CX Phone System - General' started by todd, Sep 24, 2007.
  1. todd
    Jun 9, 2007
    35
    If I’m out side of my office, can I just use any phone call my 3CX system and then use my Voip line to make a IDD call?
  2. etm_ltd
    Nov 18, 2006
    69
    Hi Todd,
    There is no problem to call your 3CX from every where while it is connected to a line or through a VOIP service.
    But I do'n think it can be used to support line transfert like you want to do.
    Why not to try to connect your Phone System as a remote user then use the PBX to call as if you were inside the company office?
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    This is a solution I came up with for another member but it is specific for situations where you wish to be routed to a predetermined number:
    You can read in context here http://www.3cx.com/forums/categorie...general-1/international-call-forwarding-2461/. I don't know it this would be of any help to you. It is the closest 3CX can do at this time.
  4. todd
    Jun 9, 2007
    35
    I can do thi use a GSM gateway now.
    Thank you for your help!
    I can do thi use a GSM gateway now. I'll try Voip line se what happand.
