How Can i set incoming call infromation?
Discussion in 'CRM / Helpdesk / App Integration' started by Hardik Soni, Jun 14, 2017.
  1. Hardik Soni
    May 22, 2017
    19
    I have implemented https://www.3cx.com/blog/docs/call-control-api/ API and i got incoming number and transfer the call ,when transfer the call on client side display only incoming number not name,but now i want to display incoming number and name also,do you have any idea about that,
    like
    incoming no:789656765
    display name :This....
    Thank You
