- Joined
- Sep 14, 2017
- Messages
- 11
- Reaction score
- 0
i want to know, how i can put the string "support" before name of the caller on the screen phone.
thanks for the help!
i solved the problem, thanks!
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
