How can I up to 12 digits internal id for 3cx
Discussion in '3CX Phone System - General' started by talkme, Aug 17, 2007.
  1. talkme
    Aug 17, 2007
    How can I up to 12 digits internal id for 3cx ?
    Exp: 10000 ==> 902123454545
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Are you want to have 12 digits extension for 3CX?
    The MAX. digits of extension at 3CX is 5.
  3. onekit
    Aug 3, 2007
    27
    I guess, he wants do international calls using
    999999999999 redirection extensions in DB. :lol:
    Really not best solution. Better wait new versions of 3cx with such feature.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi onekit,
    100% agree. It should be allow direct key in via DR.
  5. talkme
    Aug 17, 2007
    I want to do 12 digits extension for 3CX web interface.
    I make to extension id 12 digit use to postgreSQL database field.
    12 digit Test user registered 3cx system and calling to other phone numbers.
    But I didnt add new external id use to 3cx web interface.
    warning to Php file error.
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi talkme,
    Does the extension which 12 digits can registered to 3CX box or not?
    If yes. The 12 digits extension can ring other extensions or not?
    3CX web interface designed for handle max 5 digits extensions. The warming should be normal. Very interesting! I also want to try change the box can be handle 12 digits extension.
    Hi Onekit,
    Referred to your old posts. Your PHP knowledge is much more high than me. Any chance to modify the PHP files to make 3cx box to handle the over 12 digits extensions?
  7. talkme
    Aug 17, 2007
    I dont know PHP program language.
    I saw the content "user_extension_info.php" but this file made crypto used to "phpSHIELD". I m thinking write my Extensions panel for 3cx. Im using asp or aspx after include my 3cx system.
