How can I use call recording in 3cx ? where can i find info
Discussion in '3CX Phone System - General' started by lotsu99, Jul 7, 2008.
  1. lotsu99
    Jan 1, 2008
    27
    How can I use call recording in 3cx ? where can i find information about it ??
    thanks
  2. Anonymous
    Anonymous Guest
    Hi there,
    For call recording, Click Extensions - > Manage and then select an extension. Under "Other Options" check "Record Calls to and From this Extension".
    Recordings will be in C:\Program Files\3CX PhoneSystem\Data\Recordings assuming a default install location.
    Thanks,
  3. lotsu99
    Jan 1, 2008
    27
    thanks ~~
    Does the 3cx Voipclient support recording ? (or X-Lite)
