How can I use Powershell to create extensions
Discussion in '3CX Phone System - General' started by uhpadmin, Oct 27, 2017.
  1. uhpadmin
    May 22, 2017
    We are using 3CX Phone System Professional Edition v15.5.5.
    It is installed and running nicely on a linux based machine.
    We administer 3CX via an internet browser.
    I am curious as to whether we can use Powershell to manage extensions, and if so, a point in the direction would be appreciated.
    I have also read that 3CX can be integrated with Active Directory, but all the docs seem to show consoles for Windows installs.
    Any advice/direction in making it easier to manage extensions would be greatly appreciated.
  2. 12494
    12494 Member
    Apr 16, 2010
    298
    30
    You can import a spreadsheet with your Extension information using Windows or Linux versions.
    And, as you noted, it looks like the LDAP option only shows up in the Windows version of 3CX
