How can I use the VoIP client to dial any SIP URL?
Discussion in 'Windows' started by fast_ryder, Oct 30, 2008.
  1. fast_ryder
    Oct 30, 2008
    Hello!
    I recently downloaded the free VoIP client from 3CX and I like it very much.
    However I cannot dial any SIP URLs using it..
    Is there any shortcut key, like in x-Lite that i can use?
    Thanks in advance,
    Ivo Pereira
    IT Consultant
    POrtugal
  2. gpsjeff717
    Jun 5, 2008
    31
    That's a good question. I too would like to know how to dial SIP URI's through the 3CX Client...
    I'm using it to connect direct to BYOD VoIP services that support URI dialing. I just need a device that will support SIP URI dialing. My Linksys SPA2102 doesn't support URI dialing either...
  3. mbellot
    Sep 12, 2008
    9
    The 3CX client does not currently support SIP URI dialing.
    I still use X-Lite when I need that functionality.
