How do add extensions on my cloud pbx
Discussion in '3CX Phone System - General' started by ZIRARI, Mar 28, 2017.
  1. ZIRARI
    Mar 27, 2017
    8
    Hi i created my account in 3cx PBX express but i dont know how to add my extension to my server can any one please give me an idea to do that ?
  2. AlexDBarrett
    Jan 25, 2011
    71
    9
    Have you logged into the 3CX Dashboard?
    ZIRARI likes this.
  3. agp
    agp 3CX Team
    Aug 19, 2015
    140
    21
    You should have configured at least one extension while going through the PBX Express Wizard. (Step 6)
    In any case, you can manage that extension and/or others via the Management console. You should have received an email containing all the information you need to access it. (URL + Credentials)
    Here's a link to the Admin manual which explains how to manage extensions: https://www.3cx.com/docs/manual/extension-management/
    ZIRARI likes this.
  4. ZIRARI
    Mar 27, 2017
    8
    Thank you for your quick response ;
    Yes i logged to the dashboard , this is the screenshot of my dashboard and my extension .
    is it necessary to have a SIP provider to make a call between two 3cx softphone ??
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @ZIRARI,
    If the two softphones are connected to the same PBX then they can call each other directly without having to set up a voice provider.
    ZIRARI likes this.
  6. ZIRARI
    Mar 27, 2017
    8
    Thank You YiannisH for your reply ,
    But how i can Configure my extension to my Cloud Pbx , i Used my public Ip but my extention won't registred to my server .
    did i miss something ?
    this is the screenshot of my extension
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Please enable the 3CX tunnel when out of office and try again. Also keep the settings included in the welcome email default.
  8. ZIRARI
    Mar 27, 2017
    8
    I used My tunnel but it's still not working
  9. YiannisH_3CX
    May 10, 2016
    6,016
    421
    What version of 3CX client are you using? From the screenshot you do not appear to be using the latest one.
    Please make sure that you are running the latest version of 3CX client and that under your extension settings in the management console the tunnel option is also enabled. Then send a new welcome mail and reprovision the client.
    If that does not work please try and provision an IOS or Android client using the same welcome email and try again using 3g/4g and let us know if that works
  10. ZIRARI
    Mar 27, 2017
    8
    Hello YiannisH ,
    I installed the Last version of 3CX client but i didn't receive even the welcome Email .
  11. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Did you set up your SMTP settings correctly? Navigate to settings / mail and make sure that information there are correct. Then click the test button and see if you can receive the Test email. If you can't you need to set it up correctly. If the test passes then go to Extensions highlight your extension and press send welcome email
  12. AlexDBarrett
    Jan 25, 2011
    71
    9
    Google Cloud will not allow direct email from the 3CX system. Which cloud provider are you using?
  13. ZIRARI
    Mar 27, 2017
    8
    thank you sir for your Help and these detailed information , Now my 3cx client was provisioned with the email and connected to my server correctly .
    Now im using just the terial , can i activate it ?
  14. ZIRARI
    Mar 27, 2017
    8
    Hello AlexDBarrett
    i'm using just the terial of Pbx Express , i didn't yet use a provider i test it just in the network
  15. YiannisH_3CX
    May 10, 2016
    6,016
    421
    That depends what you used to install the system, if you used the 7 days trial then you cannot as this is hosted by us and will expire in 7 days. This is just for testing purposes and should not be used for production systems.
    If you used your own account to deploy the PBX then you can upgrade the key to any version you want.
    https://www.3cx.com/docs/pbx-google-cloud/
  16. Strass67
    Jul 27, 2017
    I have a similar problem with PBX. I have activated the SIP trunk (provided by OVH) and I try to configure my first extension.
    I have the green light on the trunk page but impossible to have it on the extension page. I never received the email.
    Thanks for your help.
