How do extension can make outbound call
Discussion in '3CX Phone System - General' started by Anonymous, Oct 17, 2006.
  1. Anonymous
    Anonymous Guest
    How do extension can make outbound call through VOIP Provider, and also is this possible that I can use DID as a extension.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    OUtbound call prefix
    When you create a PSTN or VOIP line, it will become the default line to use for external calls. By default a 0 is used to get an outside line.
    You can change this behavior by modifying / creating outbound rules.
