- Joined
- Dec 17, 2017
- Messages
- 64
- Reaction score
- 1
I used the PBX Express to install 3CX on AWS so it's Debian 8 I believe. When on VPN there's no audio on calls and our consultant said it's because 3CX has no route back to our office devices, and that I need to "add a static route on 3CX to 192.168.0.4/24 with the LAN of your VPN Server as the next hop, that will fix your issues." I don't see how to do that in 3CX but he then said "you do it from Linux or Windows, it's very easy to do" and then pointed me to a website that said for Debian 8 one command is:
ROUTE ADD -NET 10.10.10.0 NETMASK 255.255.255.0 GW 192.168.1.1 DEV ETH0
When I type Route on the 3CX command line it says command not found. Is there a different way I'm supposed to do this?
