How do I change a provisioning template on a phone?!
Discussion in '3CX Phone System - General' started by wgordon, Aug 6, 2016.
  1. wgordon
    Aug 6, 2016
    5
    I see where I can assign a template to a NEW phone, but once the phone is assigned, I don't see anywhere that I can change the template...unless I need to manually copy and paste the config XML from the template file?!
  2. sbalk23
    Aug 6, 2016
    i fought this for 2 hours....i just replaced the default one. then is lost all my phone mac..almost ready to go back to 14
  3. wgordon
    Aug 6, 2016
    5
    Yup, I had a heck of time with the MACs too... Thankfully my 3cx install is in a VM, and I had a pre-upgrade snapshot.... I just reverted and grabbed the MACs from there
