Solved How do I change the logo on Yealink T46G?
Discussion in '3CX Phone System - General' started by msnyder, Jul 25, 2017.
  1. msnyder
    Jul 20, 2017
    24
    I'd like to replace the 3CX logo with our company logo, but can't find in the guides how to do it.
    Shane Farmer likes this.
  2. Shane Farmer
    May 15, 2017
    24
    Would be interested in this for 23G/29G/48G, as well. I found one guide, but it didn't work, or I messed something up.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    47
    HI,
    You can find the default 3CX logo's here:
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\<YOUR CODE>\logo
  4. msnyder
    Jul 20, 2017
    24
    I'm running the Linux version...
  5. msnyder
    Jul 20, 2017
    24
    I seem to have found the directory, but no matter what size I edit the image to, it's always stretched and out of proportion...
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    480 x 272 is the pixel count on that display. Have you done this?
  7. msnyder
    Jul 20, 2017
    24
    Yes, I even made it smaller...
  8. craigreilly
    Feb 1, 2012
    3,545
    298
    thats the pixel count of the logo I am using and the pixel count of the display.
  9. msnyder
    Jul 20, 2017
    24
    I got it working!
    I made the logo smaller, then put black space around it making the full size 480x272 and it looks great!
    Thanks!
  10. craigreilly
    Feb 1, 2012
    3,545
    298
    480x272 - works every time on the 46 line. o_O
