How do I change the VPC when using PBXExpress to AWS
Discussion in '3CX Phone System - General' started by checkinyyz, Dec 18, 2017.
  1. checkinyyz
    Dec 17, 2017
    62
    When I do PBXExpress on AWS it installs to the default VPC which I do not want. How do I move it into a proper one with the correct subnet?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    not an expert on AWS but in GCP stop instance, select VPC, start instance.
