How do I connect to Skype using a VPN?
Discussion in '3CX Phone System - General' started by shaunstevin, May 28, 2012.
  1. shaunstevin
    May 16, 2012
    9
    I just connected to my uni's VPN, and everything except for Skype and AIM works perfectly. Skype and AIM won't even let me log in. I've tried changing the proxy settings so that they match my web page settings and changing the ports to match, but it still won't work. Help? Is there any way I can get Skype and AIM to work with VPN?
    10,355
    223
    You may have better luck on a forum dedicated to one of those services.
    I suspect that they are being blocked deliberately, check to see if other users are experiencing the same issues.
  3. rjsmr51
    May 29, 2012
    They are likely blocking VOIP. Aim may also be on their block list. It happens all the time as evidenced by the number of web sites that mention skype blocking.
    __________________________________________________________________________________________________________________
    Unblock WeSites Address
