how do i connect to the management console
Discussion in '3CX Phone System - General' started by aftermarket, May 13, 2009.
  1. aftermarket
    May 13, 2009
    84
    hi
    thought i'd give this 3x stuff a go installed it all ok however when i go to the management console it doesnt display anything. the webserver has been started in services.msc. the program was installed before with an earlier version that did work this it was v 6 . any ideas?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Re: webserver not working
    Hello and welcome,
    did you point your browser to
    http://x.x.x.x:5481
    where x.x.x.x is your server ip
  3. aftermarket
    May 13, 2009
    84
    yes i did but it just comes up page can not be displayed any ideas?
  4. ciscotech2007
    Jan 27, 2009
    94
    It depends on if you installed IIS or Cassini web servers.
    More information here:
    http://www.3cx.com/manual/3CXPhoneSystemManual7/phone-system18.html
    You need .NET 3.5 framework at least... I have had issues with lower .NET frameworks. And you need to verify .NET has ASP.NET enabled
  5. aftermarket
    May 13, 2009
    84
    i installed the Cassini webserver and have tried connecting on the correct port. how would you verify the .net and asp.net?
    thanks
  6. ciscotech2007
    Jan 27, 2009
    94
    Sounds like you need to install MS .NET Framework;
    http://www.microsoft.com/net/
