How do I disable inbound authentication?
Discussion in '3CX Phone System - General' started by ingram, Oct 24, 2013.
  1. ingram
    Oct 24, 2013
    11
    I use IntelePeer as my SIP Trunk provider. They do not require inbound authentication. How do I disable it in 3CX? It seems to be enabled by default, and IntelePeer says I have to disable it before the call will go through.
    Here is a screenshot of an inbound call in wireshark:
    [​IMG]
