How do I do a TCPDUMP
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 7, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    I have setup a SIP Trunk with FlowRoute and it has registered but I can not receive calls nor make them. They want me to run a TCPDUMP
    How do I do this and where can I find the software that does this and install it or is it already in 3CX
    10,586
    252
    Within 3CX You will probably be using the Server logs. They will show you where the call is routing and what the response is once the call is sent. The verbose option provides the most detail. Anything beyond that will probably require the use of a tools such as Wireshark. That will show you all messages sent and received.
    If the trunk shows as registered (you do have it set to register, in the trunks settings? otherwise it will show as registered, even if it isn't), then the provider should be able to tell you what they are seeing.
  3. petewatterschats
    Jan 19, 2016
    151
    and one registered should it work?
    How do I know if If it set to register, in the trunks settings?
  4. leejor
    10,586
    252
    If you open the VoIP provider you created, you will see an Advanced tab at the top. Click on that and about half way down you will see...Require Registration for... and a drop down menu. Unless there is some specific reason not to, it should be set to In and Outgoing calls.
  5. petewatterschats
    Jan 19, 2016
    151
    Checked it and that was the way it was
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
