How do I forward a voice message to one or many extensions?
Discussion in '3CX Phone System - General' started by negoceb, Feb 13, 2008.
  1. negoceb
    Aug 12, 2007
    I have a situation where I have to get information out to several group members in the office.
    The best way for me to get a hold of these members is by their extensions.
    Is there a solution that will allow me to send a voice message to several line extensions?
  2. eddietang
    Oct 3, 2007
    31
    We forward our voicemail currently using email attachment which works perfectly. I don't think its possible to do it like how Asterisk does it.
  3. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    That's right. But since 3CX allows you to go in to the voicemails of others from anywhere you could setup a fake extension with voicemail which is the cetnral point for your messages. Everyone needs the code for that one and on certain times they listen to it. That is the less traffic costing option, since sending a voicemessega to all the email accounts is much more heavy.
    You could send everyone a mail that they have to listen to the central voicemessage for all workers or something.
