How do I get 4287
Discussion in '3CX Phone System - General' started by LocalAg02, Mar 25, 2008.
  1. LocalAg02
    Feb 15, 2008
    7
    Where do I download the new version of 3CX. My Versions/Updates say I need to go to version 5.1.4287, but I dont know where to get the update? Any help?
  2. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    Try the update function in the start menu.
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    After you run the update from the computer where 3CX is installed, go check the version number of the 3CXPhoneSystem.exe. You will see that it shows version 5.1.4287.0 although the server status webpage will say otherwise. (To check that out use the file explorer, navigate to the directory where 3CX is installed , go under "bin" and check the properties of the file 3CXPhoneSystem.exe). Since it's just an update, apparently the setup page is not properly adjusted, but will have the latest.
    Make sure that you run the update program on the computer where 3CX is installed. You don't do it from the webpage.
    Halea
  4. h2009
    h2009 Member
    Mar 15, 2008
    447
    Remember to backup your database just in case something bad happens.
  5. LocalAg02
    Feb 15, 2008
    7
    I forgot about the non web based update function. Thanks.
