how do i get this to wrk with my Gizmo5 account?
Discussion in 'Windows' started by gatornuke, Jul 17, 2009.
  1. gatornuke
    Jul 16, 2009
    Ok, so i just have a normal SIP account through Gizmo5. I figured i could just download the voip phone since i don't really need all the other enterprise stuff, i just want to make and receive phone calls, that's all. The problem is that i can's seem to be able to reconcile my info with what's requested in the phone setup. i have the following info:
    Username: user_name
    Password: my_password
    phone: 17475555555@proxy01.sipphone.com
    I think i can figure out what to put in for "id" and "password" in connection settings but extension? local IP of PBX? remote tunnel? What are they asking me here? How do i tell it to just log in to proxy01.sipphone.com?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Search on forum for Gizmo or Gizmo5 and you will have all information about it.
    Regards
