How do I know PUSH is working?
Discussion in 'Android' started by Doogie, Jul 18, 2014.
  1. Doogie
    May 27, 2014
    9
    I installed the current Version of 3CXPhone V12 on my Samsung S4 and followed the steps i found here http://www.3cx.com/blog/docs/3cxphone-push-technology/
    to enable the PUSH option.
    But how can I check if i was successfull? The phone battery is still losing 20% in one hour, at this rate it's impossible to use in a professional environment. So, I doubt that everything went right...
    Any way to confirm if push is working or not?
    thanks
    Doogie
  2. roland_3CX
    roland_3CX New Member
    Mar 28, 2014
    101
    7
    hi Doogie,
    Simply let the phone go to sleep and then trigger a call to your 3CXPhone. If you have properly configured it, PUSH technology will wake up the smartphone when a call is received. In other words you are not required to keep the phone active to be able to receive calls.
  3. Doogie
    May 27, 2014
    9
    Thanks, got it!
    but it didn't proove quite practical, as it takes a lot of time for the app to launch, build up the tunnel and connect... most of the times the call is already ended by then... :(
    So, I'm just using it for changing status then...
  4. Deepest
    Nov 9, 2012
    45
    Hi Doogie
    My solution to this issue is to setup Available 2 profile with a longer divert time to give you time to open the push message and everything to register and connect and use this profile when i am out of the office.
    Cheers
  5. Doogie
    May 27, 2014
    9
    good thinking!
    Will give that a try, thank you!
