how do i make Skype to Skype calls through Skype gateway
Discussion in '3CX Phone System - General' started by jwnesbitt, Sep 29, 2009.
  1. jwnesbitt
    Sep 19, 2009
    48
    How do I set the gateway / Outbound rule so that if user 1 dials a Skype ID, it gets routed via the Skype Gateway ?
    I have set a rule as follows
    dial 611
    drop 3 digits
    prepend with the specific skype id that i have associated with the number 611.
    This works fine, but only works with numbers that I manually associate with an ID via prepend.
    Is there a way of automating the procedure ?
    If i set the rule as follows
    dial 8skypename
    drop 1 digit
    route via Skype gateway as above which works, I get "called number does not exist"
    Jody
  2. jwnesbitt
    Sep 19, 2009
    48
    Just to say this is now working
    Thanks to Steve Corrigan from 3Cx who pointed me in the right direction
    Had to make outgoing rule with
    a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z
    as the prefix range
    Jody
  3. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Sorry for my ignorance, but, maybe you can provide a more detailed example of getting this to work.
    I have created an outbound rule by dialing, say 9, and the stripping the 9 and just using the skype id. It is already set to go out of the skype gateway. Using a 'normal' phone, are you guys just dialing the 'digits' represented by the skypeID? For example, SkypeID is ABC. Are you dialing 222 (translating the ID to digits) to make this work? I can make regular PSTN calls in/out using the skype gateway, but, I am at a loss to dial SkypeID'S?
    Thanks for everyone's help.
    Jason
  4. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Part 2 - I have a 'master' port setup for PSTN skype calls. Is there any other config/ports I have to add to the Skype gateway to do Skype-to-Skype calls?
    Thanks again.
    Jason
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,441
    61
    Hope this one helps:
    http://www.3cx.com/forums/cannot-make-outgoing-calls-11949.html#p61527
  6. Vali_3CX
    Dec 12, 2008
    1,441
    61
    If your gateway has only one channel, you should be able to make outbound calls anyway.
    Now, supposing your gateway has three channels, having as corresponding outbound rules 0, 1, 2
    - if all channels are the same (no master) you should be able to make outbound calls using any 0, 1, 2
    - if channel 0 is master, then you should be able to make outbound calls using 1 and 2. By 0 is possible only when 1 and 2 has both calls in progress.
  7. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Here is a log of the attempted call. I have an 'outbound' rule that specifies if someone dials "88", then to use the Skype gateway. I have stripped the "88" in the outbound rule.
    12:40:07.520 [CM503008]: Call(68): Call is terminated
    12:40:07.515 [CM503015]: Call(68): Attempt to reach <sip:883246123@192.168.167.33;user=phone> failed. Reason: Temporarily Unavailable
    12:40:07.515 [CM503003]: Call(68): Call to sip:3246123@127.0.0.1:6060 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6060
    12:40:07.514 [CM505002]: Gateway:[Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:127.0.0.1:5060]
    12:40:07.513 [CM503002]: Call(68): Alerting sip:10000@127.0.0.1:6060
    So, we tried a test by dialing '88echo123' (883246123) and no luck.
    Any suggestions?
    Thanks.
  8. Vali_3CX
    Dec 12, 2008
    1,441
    61
    I've already explained you how to proceed, three messages above, did you tried?
  9. j_friedrich
    Apr 2, 2009
    30
  10. Vali_3CX
    Dec 12, 2008
    1,441
    61
    Friedrich, the post you quoted is not the one I've pointed, is the one above. Shortly, try to use speedials on your hardphone.
    Quote:
    Question:
    How do you dial 5echo123 from my snom320 extention. I mean it has numbers but not letters.
    Answer:
    Unfortunately, my knowledges on hardphones are very poor, so I will tell you how I configured my Grandstream (2010), perhaps may be useful to find something similar on your SNOM: since it can be configured using a webbrowser from any computer, since it has speeddials buttons, It was easy to assign to few buttons some Skype accounts (such as 5echo123) and then to make corresponding calls using those buttons.
    Reply:
    Ur speed dial option work great.
  11. j_friedrich
    Apr 2, 2009
    30
    We had only one Skype 'master port' setup. So, we added another Skype channel setup as not a master account. Again, same error when dialing the echo123 account. We changed our outbound rule '88' to use the secondary Skype channel.
    Still nothing...
  12. j_friedrich
    Apr 2, 2009
    30
    Here are more logs:
    13:52:53.505 [CM503008]: Call(77): Call is terminated
    13:52:53.502 [CM503015]: Call(77): Attempt to reach <sip:883246123@192.168.167.33;user=phone> failed. Reason: Temporarily Unavailable
    13:52:53.502 [CM503003]: Call(77): Call to sip:3246123@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    13:52:53.500 [CM505002]: Gateway:[Skype-to-Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:127.0.0.1:5060]
    13:52:53.500 [CM503002]: Call(77): Alerting sip:10006@127.0.0.1:6062
    13:52:35.457 [CM503008]: Call(76): Call is terminated
    13:52:35.454 [CM503015]: Call(76): Attempt to reach <sip:993246123@192.168.167.33;user=phone> failed. Reason: Busy
    13:52:35.454 [CM503003]: Call(76): Call to sip:3246123@127.0.0.1:6060 has failed; Cause: 600 Busy Everywhere; from IP:127.0.0.1:6060
    13:52:35.452 [CM505002]: Gateway:[Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:127.0.0.1:5060]
    13:52:35.452 [CM503002]: Call(76): Alerting sip:10000@127.0.0.1:6060
    We setup an outbound rule '99' for our Skype 'master port' 10000. We also setup another outbound rule '88' for the secondary non-master Skype port 10006. Still trying to dial 'echo123'.
    Thanks.
  13. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    May I dial it?
    Is that your phone number?
    What is the person I need to ask for?
  14. j_friedrich
    Apr 2, 2009
    30
    We are trying to dial a Skype ID. There is the standard echo test from Skype that we want to dial. So, we dialed '88' (Outbound rule) then 'echo123'. Doesn't 'echo123' translate to 3246123 on the phone keypad? Are we missing something?
    Thanks.
  15. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Just to let everyone know, we followed the example in the first post at the top, and in the prepend field put 'echo123'. That's works. But, we want to be able to 'dial' skype ID's with normal hardphones. Is it my understanding that skype ID's can't be translated to digits and dialed with hardphones?
    Thanks.
  16. SY
    3CX Support
    Jan 26, 2007
    1,825
    We have already caught it... ;)
    9 buttons and 26+9 characters... What do you expect?
  17. j_friedrich
    Apr 2, 2009
    30
    Okay, got it. So, because we have the hardphones connected to different linksys ATA's, we will just have to program the speedial in the ata's to dial out letters and numbers. That I know we can do. Fair enough, I didn't think we could translate to digits. Had to ask if there was a way...
    Thanks.
