How do I pull other 3cX variable data ?
Discussion in 'Call Flow Designer' started by insightbill, Dec 24, 2017.
  1. insightbill
    Jul 9, 2014
    I would like to take the session.ani and grab information from that extension. For example First Name, Last Name etc. Can you provide an example of how I can use the session.ani to "read" and create other variables from the extension that is calling the CFD ?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hello @insightbill,
    In order to do that, you need to use the 3CX Call Control API, from a Launch External Script component.
    Please note that this API can be changed at any time by 3CX without further notice, so in case of upgrading 3CX your app might stop working. Therefore, you should test the app carefully with every new version of 3CX before upgrading, to ensure that it works as expected.
    Said this, what you need to do is the following:
    1) Create a text file with extension "cs" and add the C# code to call the Call Control API.
    2) You can get the Extension object using the following code:
    Extension ext = PhoneSystem.Root.GetDNByNumber(extension) as Extension;
    if (ext != null)
    // Add your code here...
    3) Call that script using a Launch External Script component, and pass the variable "session.ani" as parameter.
    Kind regards.
