How do I refresh all the phone provisioning files?
Discussion in '3CX Phone System - General' started by coreybrett, Jul 19, 2012.
  1. coreybrett
    Apr 12, 2010
    72
    I have changed the IP address of my 3CX server and had to manually update the "DEFAULTLOCALIP" option in "Custom Parameters" to reflect the new IP address. However, all my phones need there provisioning files updated to reflect that. Is there a way to trigger that without opening and closing the settings of each extension?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    I don't think it possible as each phone will have its own unique provisioning file. If you have manually provisioned the phones, then back to the web interface for each as I assume you have likely disabled the auto provision feature within the phones. If 3cx provisioned, then you need to edit the file for each and then use the reprovision button on the phone tab after highlighting which one.i doubt that changing the parameter in the system will result in a change automatically. It may be just as simple as opening up the provisioning page for a phone then hitting apply which may then re-write the file attribute with the new ip and then apply.
