How do I reset voicemail pin for a specific extension
Discussion in '3CX Phone System - General' started by abelaguilar, Dec 19, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    Hello:
    forgot password for extension voice mail and can't get it to change it. How do I reset the password since I can't get in to that extension's voice mail.
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Extensions -> Manage -> Click the relevant extension name -> Voice Mail Configuration -> PIN Number
  3. scottyork
    Jun 1, 2007
    64
    You can also change it via the new (v.5) VOIP Cient :wink:
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Use following URL
    http://3cx-box:5481/myphone/
