How do users manage their ext
Discussion in '3CX Phone System - General' started by tlachau, Feb 18, 2016.
  1. tlachau
    Dec 3, 2015
    13
    How do users manage their own extension account? Update email, set voicemail rules (send to email options), ect...
    Is this possible?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    In the Extension Settings in the Management Console in the "Options" tab you can grant each user access to the Management Console to only view their own extension settings. Then they can use their extension number as username and the password you set for them.
  3. tlachau
    Dec 3, 2015
    13
    Thank you, i just did that. It would be nice if the phone provisioning tab wasn't there! Some of our users are more daring than others and like to keep us busy so I might not turn this on.
