How do you change the # of digits of lines in the software?
Discussion in '3CX Phone System - General' started by sbutler, Mar 29, 2007.
  1. sbutler
    Mar 19, 2007
    8
    How do you change the number of digits configuration that you configure during install? I don't want to reinstall the software. I have 4 digits right now. Is it possible to change it to 7 digits?
    Thanks,
    Butler.
  2. vanDivX
    Feb 20, 2007
    36
    Re: How do you change the # of digits of lines in the softwa
    when I was installing RC2 edition over previous version which had 3 digit extensions, it didn't allow me to change the number (the field was not active) which I supposed was because I chose to keep previous configuration, I went back to where you choose to keep or not and chose not but that choice was still greyed out, meaning even reinstall might not allow you to change the number
    vanDivX
  3. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    You can only change the number of digits during install/reinstall if you don't keep your settings. Options are only 3 or 4 or 5 digits
  4. sbutler
    Mar 19, 2007
    8
    thanks all.
  5. bhavinvb
    Jul 30, 2014
    Thanks for the Information, but i would like to know if i do a backup of the 3CX and after i reinstall, will it let me restore my configuration ?
  6. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Yes but whatever extension digit length you had before is what will be restored.
  7. bardissi
    bardissi Member
    Jan 31, 2012
    318
  8. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    .. unless you hack the crap out of the XML file before the restore.. but good luck with that.
    I suppose it "can" be done.. haven't personally tried. ;)
