How do you change the ringtone
Discussion in 'iOS' started by jasit, Apr 4, 2013.
  1. jasit
    jasit New Member
    Feb 12, 2013
    173
    Is there anyway to change the ringtone? we have changed the main ringtone and it doesn't seem to matter. we would like to have just a simple ring versus the musical one that it has now.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @jasit
    The ringtone is specific to the phone model you are using. What brand/model is it? Are you configuring the phone manually or via provisioning?
  3. jasit
    jasit New Member
    Feb 12, 2013
    173
    Iphone, running the ios app 3cx phone for 3cx systems
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @jasit
    The 3CX Phone app does not provide a way to customise the ringtone.
    You may submit a feature request here: https://apps.facebook.com/threecxideas/
