How do you do trunking for 3CX without VOIP provider?
Discussion in '3CX Phone System - General' started by nicisaaclee, Aug 16, 2013.
  1. nicisaaclee
    Aug 16, 2013
    I am a student doing a project. I have installed the 3cx server on one computer and switchvox on another computer. Now, i have been trying to set up a trunk for the 3cx server so that the switchvox and 3cx server are able to communicate through X-Lite. On another note, i wish to find out how do you configure a lync client to be able to be connected on the switchvox server as well as on a 3cx server
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You may want to try setting up an extension on 3cx and then using the extension credentials to register a trunk on the switchvox side.
  3. leejor
    11,117
    329
    You might also try setting up a Bridge trunk (Master or Slave) to the other device depending on its interface capabilities.
  4. azfar69
    Aug 16, 2013
    How does one do that? Setting up the bridge trunk? Please elaborate
