How do you guys handle faxing with 3CX?
Discussion in '3CX Phone System - General' started by ingram, Jan 6, 2014.
  1. ingram
    Oct 24, 2013
    11
    How do you normally use a fax machine with 3CX and a SIP Trunk? The only information I could find was this article about a Patton M-ATA device. We ordered one and couldn't get it to work correctly. Is this the only method to send and receive faxes with 3CX, using a real fax machine (not an online faxing service)?
    I'm sure this is a common question, but I can't find an answer.
    11,283
    360
    Using a VoIP provider that supports t.38, along with an ATA that also supports t.38 as well as a fax machine that happens to work (some are better than others), is your best bet. Many users don't bother running a fax machine though 3CX and instead have it share the analogue phone line on the DSL, that can also be used (outgoing) for emergency calls (via a gateway) in the event of an ISP/VoIP provider failure. I have managed to use an SPA-2102, though 3CX ,out on a SPA-3102 gateway.
    Everything must support, and be configured to use t.38.
    http://www.voip-info.org/wiki/view/T.38
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    We usually go with an ITSP that delivers their sip trunks via an IAD and hand off one call path as an analog line.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    We dont use fax through the 3CX pbx.
    We use audio codes devices and do fax via https.
    If you want to learn me feel free to reach out.
  5. GManNAtl
    Sep 13, 2012
    58
    As stated above a provider that supports T38 is a MUST. If you don't have this, likely no ATA device will work. I use the built in fax server with good results on NexVortex. It will still occasionally fail on a small percentage of faxes.
    Otherwise just have a plain jane POTs line for a backup as others have suggested.
  6. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    I don't know if I would try this on a large volume site - however I have used it in small volume and it works fine when there is no analog line available.
    THere is a group of devices from OBIHAI.com. I've got the Obi100 - I think it cost around $40. You can connect this to a free Google Voice account to get inbound and outbound faxing over IP.
    Regards,
    Allen
  7. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    For inbound obviously any good SIP provider supporting T38 will do. We have a very high success rate with that on our trunks.
    For outbound, we use the Grandstream HT701 registered directly to one of our SIP trunk subaccounts supporting T38 or ULaw (g711u) pass trough with no trouble. Virtually all of our installations are this way.
  8. MarkWim
    Jan 17, 2014
    Hey Sigma,
    Thank you. Our 3CX system was installed 3 weeks ago and the fax never worked for sending and most of the times it failed receiving. We used one of the sip trunk companies listed and they were no help. We already had the ht701 adapters so I called you guys up. Wayne helped us out and he setup a free trunk and two of the five ht701 we have. It ran without a hitch all day and I couldn't believe my ears when your tech told us it was free and we even had a ten dollar credit on the trunk. I will be porting our service to you but please let Wayne know that he represented the company very well.
    MW
  9. sigma1
    Nov 20, 2009
    542
    Mark you are most welcome. Wayne is a terrific engineer and I am glad he was able to help.
  10. ps851112
    Feb 15, 2014
    We are new to 3cx, just setup and still working through some issues. I do have faxing working with a Patton SN4118. We sell copiers/fax machines and have been dealing with FOIP for years at our customers. My experience is a good T38 provider is required, a good internet connection with low latency and jitter; also disabling T34, downgrade to 14.4 or lower speeds, and turn off ecm on your fax machine is a must. After using the default SN4118 setup option in 3cx and configuring our fax machines with the earlier described settings we have 99% success rate with Sotel. Most high end the fax machines will allow you to modify these settings, but this usually requires an authorized service provider to get these settings changed. I've gotten Brother, Konica Minolta, Kyocera, Sharp, Toshiba to work.
