How does v15 provision Cisco SPA?
Discussion in '3CX Phone System - General' started by TSlocum, Sep 22, 2016.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    I've been having trouble with provisioning my SPA514g phones on 7.6.1. In v14, the system created XML files in the provisioning folder for each MAC address, but it doesn't seem to be the case anymore. The XML files left over from 14 aren't getting updated when I make changes to the extensions and removing them doesn't do anything. The phones are still getting provisioned from somewhere.
  2. viennatech
    May 26, 2016
    Same issue here. unable to proceed with a v15 upgrade as the phones will not connect to the https: site for provisioning. What happened to the mechanism?
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
