How doI reset Cisco 502G to factory defaults?
Discussion in '3CX Phone System - General' started by pdq, Aug 21, 2010.
  1. pdq
    pdq
    Dec 3, 2009
    82
    How doI reset a Cisco 502G to factory defaults from the web interface?
    Thanks in advance,
    Scott
    11,086
    325
    I don't know if you can. The manual.. http://cisco-systems.com.ua/upload/Cisco/spa500_admin.pdf , page 18,just shows to use the r.e.s.e.t (73738) method from the keypad. This sort of makes sense as a factory reset make changes the set to the point that you need to be physically present to get the phone back up and running.
