How: LOGFILE
Discussion in 'Windows' started by Tugi2o, Jun 26, 2008.
  1. Tugi2o
    Feb 20, 2007
    61
    in which INI-File can i specify the logging option for error search (Client).
  2. darrellchapman
    Nov 26, 2007
    268
    Since the 3CX VoIP Client maintains profiles for each user logged in to your computer, the profile INI would have to be stored in a specific Windows User Account (profile) directory. On my computer that's
    C:\Documents and Settings\[myusername]\Local Settings\Application Data\3CX VoIP Client\
    The Phone.ini that's located there has all of the user-specific settings.
  3. Tugi2o
    Feb 20, 2007
    61
    Thank you very much, thats what i was looking for...
  4. darrellchapman
    Nov 26, 2007
    268
    You are certainly welcome.
