How many 3cx phone registrations at a time
Discussion in '3CX Phone System - General' started by Ben C, Apr 1, 2016.
  1. Ben C
    Oct 14, 2014
    71
    Is it possible to register multiple 3cx clients at a time? Like 2 windows clients (1 internal and 1 remote) and 1 android at the same time?
    Thank you
    Ben
    11,116
    329
    If you mean multiple registrations, of different devices, all using the same extension number/credentials, then yes. This is called SIP Forking. All devices can place calls simultaneously, and all devices will ring, on an incoming call. You must set an option in the 3CX extension settings to allow the extension to receive more than one call at a time. If you don't and one device is on a call, then any call to the extension number will result in the call going straight to voicemail, or wherever is is supposed to go, when the line is busy.
