How many connection on one extension ?
Discussion in '3CX Phone System - General' started by cyclone76, Mar 8, 2017.
  1. cyclone76
    Mar 3, 2017
    44
    It is possible to add more than one connection on an extension.
    I added computer and mobile phone with OCX client and they ring at the same time.
    But in "Extensions configuration", i have not checked "Ring my mobile simultanepously" :
    [​IMG]
    What is it used for ?
    Thanks for help.
    Fredo
    #1 cyclone76, Mar 8, 2017
  2. daktur
    daktur New Member
    Oct 15, 2015
    225
    6
    Cyclone,
    Please note that once you have installed same extension on both windows and mobile using 3cx, the function "ring my mobile simultaneously" does not need to be active.
    This function enables the mobile phone registered on extension details to ring; that means you don't have to have internet access on you mobile since you should receive the call as a regular one, not using 3cx mobile.
    On the other hand it will consume 2SC from your resources.
    Why don't you set a different extension for your mobile if your are willing to have 3cx on it?
    Hope I could help and made myself clear.
    cyclone76 likes this.
  3. cyclone76
    Mar 3, 2017
    44
    Hello Daktur,
    I prefer not to multiply extensions by simplicity. As for Viber, I prefer that incoming calls on an extension are duplicate on the PC and the mobile phone.
    Thanks for your answer.
  4. leejor
    10,362
    227
    Ring my Mobile simultaneously would be used by those that chose not to install a 3CX extension on their device, or did not have an "always on" data Plan.
  5. cyclone76
    Mar 3, 2017
    44
    What is an "always on" data Plan" ?
    Regards
  6. leejor
    10,362
    227
    Some mobile users opt for a limited Data plan for their mobile, which means they don't leave data turned on all the time, or the monthly allotment would be gone in short order. Others don't bother adding a Data plan, and simply use Wifi when and where available.
