How setup a voip line?
Discussion in '3CX Phone System - General' started by css, Mar 6, 2008.
  1. css
    css
    Aug 15, 2007
    21
    I am currently running 5.1.4078
    I have 2 vonage lines. Currently I have them plugged into a SPA-3000. But it looks like I can just setup a voip line instead of running it through the SPA-3000 and adding a PSTN line which is currently working for me. When I go through the steps of setting a vonage I do the test and I get a firewall check failed which I pasted below sorry for all the info but I wasn't sure what you needed. If i just click next the line will register and then unregister and keeps doing this.
    I was wonder how you connect the vonage lines to the phone system. Does the line still need to be plug into a gateway, or can you just plug the vonage box into my network switch and not have it connect to a gateway at all.
    Here is the log and the errors.
    1 9000 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9000
    2 9001 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9001
    3 9002 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9002
    4 9003 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9003
    5 9004 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9004
    6 9005 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9005
    7 9006 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9006
    8 9007 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9007
    9 9008 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9008
    10 9009 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9009
    11 9010 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9010
    12 9011 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9011
    13 9012 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9012
    14 9013 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9013
    15 9014 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9014
    16 9015 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9015
    17 9016 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9016
    18 9017 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9017
    19 9018 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9018
    20 9019 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9019
    21 9020 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9020
    22 9021 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9021
    23 9022 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9022
    24 9023 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9023
    25 9024 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9024
    26 9025 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9025
    27 9026 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9026
    28 9027 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9027
    29 9028 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9028
    30 9029 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9029
    31 9030 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9030
    32 9031 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9031
    33 9031 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9031
    34 9032 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9032
    35 9032 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9032
    36 9033 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9033
    37 9034 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9034
    38 9034 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9034
    39 9035 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9035
    40 9035 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9035
    41 9036 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9036
    42 9036 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9036
    43 9037 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9037
    44 9037 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9037
    45 9038 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9038
    46 9038 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9038
    47 9039 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9039
    48 9039 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9039
    49 9040 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9040
    50 9040 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9040
    51 9041 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9041
    52 9041 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9041
    53 9042 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9042
    54 9042 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9042
    55 9043 Error (4) The STUN server returned an ip which is not accessible from outside. addrFromSTUN = 64.212.47.248:9043
    56 9043 Information (9) Port is open and can be used for calls. externalAddress = 64.212.47.248:9043
    07:52:44.153 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@3682 is scheduled in 1 minute
    07:52:44.153 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@3682; Cause: 404 Not Found; from IP:216.115.20.41:5061
    07:52:43.872 ClientRegs::Register [CM504003]: Sent registration request for 10000@3682
    07:52:28.060 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac619386939 cseq=REGISTER contact=4372065@192.168.1.5 / 3512 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:52:26.325 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
  2. darrellchapman
    Nov 26, 2007
    268
    I may be totally wrong here, but I believe that if you wish to connect to Vonage without their ATA device, you will need to contact them so that they can provide you with the Auth info.
    If anyone thinks I'm incorrect, please let me know.
    Darrell Chapman
