feestbeestzaandam
New User
- Joined
- Jun 6, 2009
- Messages
- 27
- Reaction score
- 0
I Have i problem.
My wife is going to a clinic voor 6 months.
The have there internet but only for web browsing.
When i try to connect to my vnc pc or other "normal things" from the clinic to my house i got no connection.
The have there no phone for private use and calling all day with her cell phone is expensive.
My idea was to connect the spa 1001 on the network with a cordless phone and then i can call her at her room.
Now i have a softphone on here laptop but that did not work Not with tunnel (tunnel was blockt) or with outbound proxy (the same ip adres as pbx)
I have tried it also with a hardphone (spa 1001) but again no connection.
I know that 3cx have a tunnelproxy but i cant install that on the pc's there and the port 5090 is blockt.
Is ther a other way such as installing a proxy server on port 80 and then routed to the 3cx server or is port forwarding 80 to 5060 in the router to the pbx enough.
Is there a solution and how can i do it?
I have a clear connection with other hard and soft phones from remote extentions at work etc so i almost 100% know that at my side (pbx) is everything oke.
