How the google contacts are synced to the web client?
Discussion in 'Windows' started by hub2000, Aug 9, 2017.
  1. hub2000
    Aug 9, 2017
    we are testing the 3CX system. Into the windows client i have imported the ggogle contacts (standard, not G-Suite). Its working.
    But the same contacts does not appear in the web frontend.
    Our goal would be to work in the office only in the web frontend. How the google contacts from my mobile / from google contacts will synchronize with the wen client?
    Scenario: Our empkoyess put new contacts into their mobile when they are traveling and then retreiving this info in the office via the web client.
    brg
    hub2000
